Howdy
Kompletny rozrząd- lista części numery i schematy
2010-05-15, 22:14
Jeśli ktoś szuka na amerykańskich stronach to na pewno się przyda.
Po wklepaniu do googla poszczególnych numerów częsci wyskakuje mnóstwo pomocnych fotek.
http://sohcreplace.blogspot.com/2008/06 ... 005-4.html
http://picasaweb.google.com/mcknight.r/ ... cedurePics#
http://www.explorerforum.com/forums/sho ... bers+chain
http://www.explorerforum.com/forums/sho ... p?t=208615
Notes:
The camshaft sprocket bolts are not torque to yield and may be reused.
The jackshaft front and rear sprocket bolts are torque to yield and may not be reused.
The crankshaft damper bolt is a torque to yield and may not be reused.
The following tasks require separation of the engine and transmission. Accessibility to accomplish the task is significantly improved by pulling the engine rather than the transmission.
1. Rear timing chain replacement (requires flywheel/flexplate removal)
2. Rear timing chain guide assembly replacement
3. Jackshaft removal (requires flywheel/flexplate removal)
4. Jackshaft rear sprocket replacement (requires flywheel/flexplate removal)
Related Ford part numbers:
Jackshaft/primary timing chain kit 2U3Z6D256CA includes:
Crankshaft bolt harmonic balancer E7RY6A340B
Tensioner-engine jackshaft chain YL2Z6L266AA
Gasket-cylinder/timing front cover F77Z6020AB
Sprocket/gear-engine jackshaft/intermediate 2U3Z6M264AA
Guide-engine jackshaft chain 2L2Z6K297AA
Bolt-jackshaft sprocket bolt F77Z6M264BA (included when 2U3Z6M264AA is purchased)
Sprocket/gear-crankshaft two wheel drive 2L2Z6306BA
Chain-engine jackshaft F77Z6268AB
Bolt-camshaft sprocket right hand
Bolt-camshaft sprocket left hand F77Z6279BA
Left/front timing chain cassette assembly 7U3Z6A257A includes:
Timing chain
Guide assembly YL2Z6M273AA superseded by 7U3Z6A257A
Bolt-guide assembly upper mount
Sprocket/gear-camshaft
Sprocket/gear-jackshaft front
Right/rear timing chain cassette assembly 4L2Z6M290AA includes:
Timing chain
Guide assembly
Sprocket/gear-jackshaft rear
00M12 intake manifold kit YL2Z9E473AA includes:
Lower intake manifold gasket set of six YL2Z9461AA
Upper intake manifold gasket set of two YL2Z9E436AA
Left timing chain tensioner 7U3Z6K254B
Tensioner metal O ring XU2Z6M252AA
Oil restrictor
Galley plug
Right timing chain tensioner 7U3Z6K254A supersedes XU3Z6K254BA
Right timing chain guide assembly upper postioning bolt F77Z6U000BA
Jackshaft rear sprocket retaining bolt W703167S430
Cover assy/rear of block jackshaft opening plug F77Z6026AB
Left cassette assembly lower mounting bolt W500100S300
Jackshaft chain guide mounting bolt W500100S300
Sprocket/gear-crankshaft inner four wheel drive F77Z6306BE
Balance shaft chain guide F77Z6K297BC
Balance shaft chain tensioner 1L2Z6L266AA
Seal-front timing cover E6TZ6700A
Gasket set-valve cover F77Z6584AE
Gasket-lower oil pan 4L2Z6710AA year 2000+ F77Z6710BA year 1997-1999
Gasket-upper oil pan/reinforcement section F77Z6710AA
Exhaust manifold outlet bolts (M12-1.75X54.5 H) N811747S2
Ostatnio zmieniony 2010-05-15, 22:16 przez Howdy, łącznie zmieniany 1 raz.
Wróć do „ROZRZĄD SOHC”
