FORD RECALL NUMBER: 09S09
NHTSA RECALL NUMBER: 09V399000
RECALL DATE: OCT 13, 2009
RECALL TITLE: SPEED CONTROL SYSTEM MODIFICATION
RECALL DESCRIPTION: FORD IS RECALLING MODEL YEARS 1995-2003 WINDSTAR, 2000-2003 EXCURSION DIESEL, 1993-1997 AND 1999-2003 F-250 SD THROUGH F-550 SD DIESEL, 1992-2003 E-150 THROUGH E-550, 1995-2002 EXPLORER, 1997 AND 2002 MERCURY MOUNTAINEER, 1995-1997 AND 2001-2003 RANGER, AND 1994 F53 VEHICLES EQUIPPED WITH THE TEXAS INSTRUMENTS SPEED CONTROL DEACTIVATION SWITCH (SCDS). THE SCDS MAY LEAK INTERNALLY AND THEN OVERHEAT, SMOKE, OR BURN.
RISK TO SAFETY: A VEHICLE FIRE COULD OCCUR WITH OR WITHOUT THE ENGINE RUNNING.
REMEDY PROGRAM: FORD WILL NOTIFY OWNERS THAT DEALERS WILL INSTALL A FUSED WIRING HARNESS IN LINE WITH THE SCDS. ON 1999-2003 WINDSTAR VEHICLES WITH A LEAKING SCDS, DEALERS WILL ALSO INSPECT THE ABS CONTROL MODULE CONNECTOR AND REPAIR AS NECESSARY. REPAIRS WILL BE COMPLETED FREE OF CHARGE. THE SAFETY RECALL BEGAN ON OCTOBER 27, 2009. OWNERS MAY CONTACT FORD AT 1-888-222-2751.
STATUS: 11 - RECALL INCOMPLETE
MANUFACTURER NOTES: To check for non-safety-related programs applicable to your vehicle, see
www.Ford.com <
http://www.ford.com/> or call your Ford dealer.
VIN:
FORD RECALL NUMBER: 04S20
NHTSA RECALL NUMBER: 04V442000
RECALL DATE: SEP 13, 2004
RECALL TITLE: LIFTGATE GLASS HINGE AND BALL STUD BRACKET (IF APPLICABLE) REPLACEMENT
RECALL DESCRIPTION: ON CERTAIN SPORT UTILITY VEHICLES, THE LIFTGATE GLASS STRUT MAY BECOME DISENGAGED OR THE HINGE MAY FRACTURE ALLOWING THE GLASS TO FALL AND POSSIBLY BREAK.
RISK TO SAFETY: IF THE HINGE SHOULD FRACTURE, THERE IS A POTENTIAL FOR THE GLASS TO FALL AND ULTIMATELY BREAK AND PERSONAL INJURIES COULD OCCUR.
REMEDY PROGRAM: DEALERS WILL HAVE THE LIFTGATE GLASS STRUT BRACKETS AND GLASS HINGES REPLACED. FOR THE VEHICLES BUILT FROM AUGUST 1, 2000 THROUGH MARCH 3, 2002, THE DEALERS WILL REPLACE THE HINGES AND LIFTGATE STRUT BRACKET. ON VEHICLES BUILT FROM MARCH 3, 2002 THROUGH JUNE 23, 2003, THE DEALERS WILL ONLY REPLACE THE HINGES. THE RECALL BEGAN ON SEPTEMBER 30, 2004. A POSTCARD WAS SENT TO OWNERS ON DECEMBER 27, 2004, ADVISING THEM THAT PARTS ARE NOW AVAILABLE. OWNERS SHOULD CONTACT FORD AT 1-800-392-3673.
