2016-10-30, 19:59
To jest geometria dla 2007, możliwe że są te same:
Front
Camber:
Left -0.5° ± 0.75°
Right -0.5° ± 0.75°
Total/Split 0° ± 0.75°
Caster (Explorer, Mountaineer):
Left 4.4° ± 0.75°
Right 4.6° ± 0.75°
Total/Split -0.2° ± 0.75°
Toe (positive value is toe-in, negative value is toe-out)
left -
right -
total/split 0.20° ± 0.20°
Rear
Camber
Left -0.5° ± 0.75°
Right-0.5° ± 0.75°
total/split 0° ± 0.75°
left 0.05° ± 0.20°
right 0.05° ± 0.20°
total/split 0.10° ± 0.20°
2008
Item LH RH Total/ Split
Front
Camber -0.5° ± 0.75° -0.5° ± 0.75° 0° ± 0.75°
Caster (Explorer, Mountaineer) 4.4° ± 0.75° 4.6° ± 0.75° -0.2° ± 0.75°
Toe (positive value is toe-in, negative value is toe-out) — — 0.20° ± 0.20°
Rear
Toe (positive value is toe-in, negative value is toe-out) 0.05° ± 0.20° 0.05° ± 0.20° 0.10° ± 0.20°
V4 na lato: VFR 750F
V6 na cały rok
