explorer_u2
Reduktor BW4405
2012-03-16, 17:22
Ja sobie tu wkleje interesujace rzeczy, bo ciagle szukam a to wszystko po różnych tematach porozwalane. Jestem na etapie regeneracji starych tarczek. I tu moje pytanie czy ktoś takie cuda już robił ? Jutro wkleje tarczki z wymiarami.
A to rocznikowo co i jak:
jesli chodzo o ceny to u nas podobne :-/
a w stanach :eek:
http://www.riversidegear.com/categories ... ain-1.html
a tu jaki reduktor w jakim roczniku:
(niestety nie wyjaśnia to jeszcze sprawy reduktora Fynn)
1. 2002 EXPLORER (electric shift) front cup yoke, rear circular flange, w/o speedo hole Borg Warner BW4411
2. 2002 EXPLORER viscous drive, front cup yoke, rear circular flange, w/o speedo hole Borg Warner BW4410
3. 2002 EXPLORER (electric shift) front cup yoke, rear circular flange, w/o speedo hole Borg Warner BW4411
4. 2002 EXPLORER viscous drive, front cup yoke, rear circular flange, w/o speedo hole Borg Warner BW4410
5. 2002 EXPLORER (electric shift) front cup yoke, rear circular flange, w/o speedo hole Borg Warner BW4411
6. 2002 EXPLORER viscous drive, front cup yoke, rear circular flange, w/o speedo hole Borg Warner BW4410
7. 2002 EXPLORER AWD Borg Warner BW4403 2001-99
8. 1998-01 EXPLORER (electric shift) (front & rear speed sensor) torque on demand, front cup yoke, rear circular flange w/o speedo hole Borg Warner BW4405
9. 1999-00 EXPLORER AWD Borg Warner BW4403
10. 1998-00 EXPLORER (electric shift) rear circular flange front cup yoke w/o speedo hole, w/o sensor hole Borg Warner BW1354
11. 1996-98 EXPLORER (electric shift) front cup yoke, rear circular flange torque on demand, front and rear speed sensor, speedo hole Borg Warner BW4405
12. 1996-98 EXPLORER (electric shift) rear circular flange front fixed yoke with speedo hole, w/o sensor hole Borg Warner BW1354
13. 1996-98 EXPLORER all (manual shift) Borg Warner BW1354
14. 1995-98 EXPLORER (electric shift) rear circular flange front fixed yoke with speedo hole, w/o sensor hole Borg Warner BW1354
15. 1995-98 EXPLORER all (manual shift) Borg Warner BW1354
16. 1998 EXPLORER viscous drive, front cup yoke, rear flat circular flange w/o speedo hole Borg Warner BW4404
17. 1996-97 EXPLORER viscous drive front and rear flat circular flange with speedo hole Borg Warner BW4404
18. 1995-97 EXPLORER (electric shift) circular rear flange, fixed front yoke torque on demand, front & rear sensor, speedo hole Borg Warner BW4405
19. 1997 EXPLORER viscous drive, front cup yoke, rear flat circular flange w/speedo hole Borg Warner BW4404
20. 1991-95 EXPLORER (electric shift) with speedo hole, with sensor hole fixed front output yoke Borg Warner BW1354
Ostatnio zmieniony 2012-03-16, 17:22 przez explorer_u2, łącznie zmieniany 1 raz.
madakelus
Re: Reduktor BW4405
2012-03-17, 10:04
to jak cos bedziesz wiedzial o tych tarczkach - gdzie kupic/zregenerowac to tez tu wrzuc
explorer_u2
Re: Reduktor BW4405
2012-04-03, 03:46
tyle zostało z tarczek
Re: Reduktor BW4405
2012-04-03, 08:08
Oooo, no to się pojeździło :-D
explorer_u2
Re: Reduktor BW4405
2012-04-26, 16:50
Panowie może ktoś podjechać i sprawdzić czy pasują te tarczki, niby tak ale nie zamówie dopóki ktoś nie potwierdzi... dziekuje :-P
http://www.midparts.com.pl/pl/p/5R55NWA ... a-OEM/2688
lukkosz
Re: Reduktor BW4405
2012-05-02, 22:40
Hej :)
Dołączę się do tematu :) mój mechanik stwierdził iż padły w reduktorze tarczki. Model reduktora to 7GA 44-05-000-008 BORG F77A-7A195-GA, z tego co wyczytałem to odpowiednik BW 4405. Czy podrzuci ktoś czy pasują te tarczki co kolega podał powyżej? A może jest inne pewne źródło?
Pozdrowionka i z góry dzięki za okazaną pomoc :)
Re: Reduktor BW4405
2012-05-02, 22:48
Najpewniejsze masz tu. Ja zamawiałem tam do mojego i byłem zadowolony, tylko ja uszczelniacze.
http://www.drivetrain.com/parts_catalog ... w4405.html
madakelus
Re: Reduktor BW4405
2012-05-03, 21:01
explorer_u2,
i jak tam, udalo Ci sie je dostac/wymienic... bo myslalem ze mam w calkiem niezlym stanie teraz jak patrze na Twoje zdjecia to moje wygladaja niemal identycznie (ale przod mi się zapina, Tobie tez?)
explorer_u2
Re: Reduktor BW4405
2012-05-04, 06:49
mnie nie zapinał przy tych tarczkach, kupiłem reduktor na części z rozwalonym łańcuchem i powymieniałem wszystko... :-P
Te tarczki w midi... nie sprawdzone , ale i tak brakuje u nich przekładek a one też maja powłoke ścierną :cry:
Re: Reduktor BW4405
2012-08-31, 20:56
to ja pciągne ten temat :-) i mam pytanie czy i gdzie dostałeś tarczki ja szukam i szukam i dupa :-D
Re: Reduktor BW4405
2012-08-31, 21:10
Re: Reduktor BW4405
2012-08-31, 21:19
patrzyłem ale może to źle robilem , łancuch już mam ( trafiłem w fajnej cenie ) tylko tych tarczek brakuje do szczęścia :-/
Ostatnio zmieniony 2012-08-31, 21:43 przez Kojot, łącznie zmieniany 2 razy.
madakelus
Re: Reduktor BW4405
2012-09-01, 09:17
ja juz kiedyś to patrzyłem i wydaje mi sie ze to bedzie ta część ale pewnowści nie mam...jak by ktos mogl potwierdzic to moze i sam bym sie skusil...
TRS-345550AK
Clutch Housing Assembly (includes housing, clutches and steels
$279.69
tyle ze to jest chyba całe kompletne z obudową
ALT625003
Clutch Pack
$198.58
a to chyba sa same tarczki... belbym tego pewien gdybym wiedzial co to jest te dwie nastepne pozycje
ALT138730 Friction, Internal 19 spline (5 per clutch pack)
1995-99
$75.58
ALT138731 Friction, External 31 spline (6 per clutch pack)
1995-99
$75.38
Ostatnio zmieniony 2012-09-01, 09:29 przez madakelus, łącznie zmieniany 1 raz.
Re: Reduktor BW4405
2012-09-01, 09:31
tak to ta część z tym że to cały kosz z tarczkami patrzyłem na innych stronach i też tak sprzedają najwyraźniej występuje tylko w pakiecie i wymienia sie cały kompl. ;-)
madakelus
Re: Reduktor BW4405
2012-09-01, 09:34
a te czesci nizej to nie beda same tarczki?
