kaczy998
Migająca kontrolka OD i błąd P0796
2014-01-09, 20:57
Witam. Od paru dni po przejechaniu paru km zaczyna mrugać mi kontrolka OD. Skrzynia pracuje prawidłowo (tak mi się wydaje) 5-ty bieg działa i konwerter też zapina się. Poziom oleju prawidłowy kolor różowy niewiele ciemniejszy od nowego i nie śmierdzi, Olej i filtr wymieniany w marcu 2011r po naprawie łożyska jednokierunkowego. Nie wiem o co chodzi ale mnie denerwuje ta kontrolka. Gaśnie ona po ok. 2 minutach. Nie sprawdzałem w trasie co będzie dalej - tylko krótkie odcinki.
albricht
Model Explorera: Jeep
Re: Migająca kontrolka OD i błąd P0796
2014-01-09, 21:27
Jak już to hamulca jednokierunkowego.
Podłącz kompa będzie wiadomo co boli pacjenta
Jeep Grand Cherokee 5,2
Honda Accord 2,7l wersja USA
Klubowicz śp. Rafaello-Mk
2014-01-09, 21:41
Thanks for the input X24,
I'm baffeled! It would be the oddest coincidence if I started having tranny problems immediately after I started messing with my intake today....it would be just my luck too and i wouldn't even know....
To give a little more background...
exactly 1 week ago I brought my vehicle in to the dealer because I had a flashing overdrive light and it was kicking in and out of OD as I was driving.
The Dealer pulled a code:
P0796 and fixed the problem:
as stated on Invoice:
"Replaced Solenoid Body, R and I Trans Pan, R and I Solenoid Body and main control. Replaced filter, refilled trans, cleared codes. PCM calibration and Trans shift stradegies were updated per TSB. "
In addition, I did a 30,000 mile scheduled maintenance which included a whole slew of things and everything checked out fine. And my truck has been driving perfect for the past week and only crapped out when I messed with it....figures...my luck, if it was me or just a coincidence with more tranny problems.
Thanks again, I'll will update the post as I have news...hopefully the good kind, and as always any other thoughs or comments would be awesome....
on a separate note, I just got and started using my AutoTap Diagnostic tool...and I have to say it is a very cool and useful, and fun investment...I'm very happy with it
sorki ale tylko tyle znalazłem
Ostatnio zmieniony 2014-01-09, 21:42 przez śp. Rafaello-Mk, łącznie zmieniany 1 raz.
kaczy998
2014-01-09, 22:11
łożyska jednokierunkowego - tak ładnie na fakturze miałem napisane :) . Moim elmem i ScanXLPro tylko to mi wyskakuje P0796. Może na początku przyszłego tygodnia uda mi się go jakimś kompem sprawdzić. Mam nadzieję że nie poszedł znowu blok elektrozaworów - wymieniany 3,5 roku temu przy okazji przeróbki skrzyni do napędu na 4x4 )Chociaż znalazłem nowe za 160 dolarów z tąd: http://www.800700tran.com/level.itml/icOid/336 Nie wiem tylko czy można jeździć takim codziennie jakieś 20 km
Ostatnio zmieniony 2014-01-09, 22:12 przez kaczy998, łącznie zmieniany 1 raz.
2014-01-10, 03:58
Prawdopodobnie masz do sprawdzenia regulator ciśnienia w płycie sterującej.
kaczy998
2014-01-10, 08:33
Możesz mi napisać gdzie to się znajduje i jak to sprawdzić. Mam jeszcze ten stary solenoid który rzekomo się zacinał (tak mi powiedzieli podczas przeróbki skrzyni - ja przed nie widziałem jakiś nieprawidłowości)
2014-01-10, 09:11
Na początek porozpinaj kostki i posprawdzaj czy nie przyśniedziały styki w kostkach, równie dobrze może to być błąd elektryczny.
Nie masz innego ujęcia tego elementu?
kaczy998
2014-01-10, 18:45
Tu masz inne zdjęcia:
5r55w-complete.pdf
A tu cała budowa skrzynki
(6.38 MiB) Pobrany 436 razy
Ostatnio zmieniony 2014-01-10, 18:46 przez kaczy998, łącznie zmieniany 1 raz.
2014-01-10, 19:39
Ten schemacik skrzynki też mam. Powiem szczerze, nie mogę się wyznać z tych obrazków. W opisie elektrycznym są 4 elektrozawory a w zdjęciach widzę tylko 3 (chyba że jakoś źle patrzę, co też jest możliwe) te 3 jednakowe powinny być OK, winą obarczał bym ten czwarty, ale nie jestem w stanie jednoznacznie pokazać który to jest. :oops:
karmel
2014-01-10, 20:00
4 to może lockup?
kaczy998
2014-01-12, 19:04
Może ktoś z okolicy Wrocławia lub Poznania by mi pomół zdiagnozować tego mojego potwora. No i czy to możliwe że po 3-latach i przejechaniu ok 30tyś km padły znowu elektrozawory. Auto nie wysilane więc nie wiem o co chodzi?
kaczy998
2014-01-12, 22:17
Sprawdziłem moje stare elektrozawory i tam również elektrozawór kontroli ciśnienia C kuleje. Udało mi się rozebrać i porównać elektrozawór B z C i wydają się identyczne. We wtorek wyciągam moje elektrozawory i porównam. Jeśli tam również padł ten elektrozawór to podmienię go ze starym B. poniżej pokaże wam zdjęcia
A to reszta płyty
winne mogą być też te oringi - zauważyłem mały przeciek podczas testowania działania zaworu c
Wyciągnięte elektrozawory
Rozpiska rozmieszczenia elektrozaworów i złącza
rozpiska złącza.jpg (49.15 KiB) Przejrzano 9375 razy
Złącze - rozpiska pinów
Ostatnio zmieniony 2014-01-12, 22:20 przez kaczy998, łącznie zmieniany 1 raz.
2014-01-12, 22:51
Błąd dotyczy zaworu C o czym pewnie wiesz.
kaczy998
2014-01-12, 23:28
Tak, wiem. Zastanawiam się czy w razie czego ten stary zawór B mogę wsadzić w miejsce tego walniętego - wyglądają identycznie. Wymienię tylko oringi na nowe bo ewentualny przeciek pewnie też będzie miał wpływ na działanie.
A tak poza tematem St. Gierałtów to w kotlinie kłodzkiej koło Stronia Śląskiego
Ostatnio zmieniony 2014-01-12, 23:31 przez kaczy998, łącznie zmieniany 1 raz.
2014-01-13, 05:40
W przypadku zamiany musisł byś sprawdzić na sprawnych ich oporność. Próbował bym zadać pytanie w tej sprawie w midpartsie, może oni wniosą coś nowego i konkretnego w temacie.
P.S. Tak to okolice Stronia Śl. w Polsce jest tylko jeden St. Gier.
